yanmar 2020 with a v tech v2 loader
   / yanmar 2020 with a v tech v2 loader
At the very beginning of the video is the pressure reading of when the 3 pt was raised. The other changes are when I curled up and then down. The curl only works when I move the joy stick.
   / yanmar 2020 with a v tech v2 loader #12
So you were reading the same relief pressure on the 3pt?
I could be wrong, but I am thinking that curl force is usually greater than lifting force.
Yes the 3 pt relief pressure is the same as the curl and the bucket lift
   / yanmar 2020 with a v tech v2 loader #14
Have you did a cyl test yet?
Your pump appears to be working for pressure, but you don't know the flow rate.
To test a cyl, you supply fluid to only one cyl at a time. Plug the other hoses
With the cyl fully retracted remove the base end hose and apply pressure to retract.
The relief may come on, but look to see if fluid continues to pour from the base end port.
If it does, then you know the seals are bad.
Do this for all cyl to check for cyl integrity.
To check the valve, you need a good cyl. Put a load on the cyl at full extension and put the lever to neutral. If the load descends, then the valve is leaking.
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2025 JMR 36in Mini Skid Steer Bucket (A55787)
2025 JMR 36in Mini...
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
