Yanmar 186 crack in cast iron housing
   / Yanmar 186 crack in cast iron housing #11
I'm curious what model backhoe did this?
If I could find one small enough for my YM186D then I would no longer need my YM240 that is now dedicated to a 3-point backhoe. I'm sure my present hoe mounted 3-point on the YM186D would be a disaster, so I'm looking for the proper smaller hoe that came with YM186D originally. I hope it wasn't that model hoe that damaged your YM186D.
Not sure what the make is as it has no ID on it, I have some pics and one of the crack on the bell housing to.
   / Yanmar 186 crack in cast iron housing #13
I don't recognize that backhoe but it looks gorgeous with the nice paint.
I like that bar that the operator faces, you have something to lean on if you stand up to look at the excavation. There is nothing like that on the Kubota/Yanmar backhoe I have (on the YM240) in fact I added a handle to the rear of the hydraulic controls for better balance as I climb up to the seat. This picture of an Ebay Yanmar with same backhoe I have, shows what I mean. There's nothing to grab on to and some risk of bumping the control levers.
Looking at your photo of the loader mount, maybe extending an under carriage clear from the backhoe to the front bumper would reduce the stresses that caused that crack.
Hi Cal yes I added that pipe when I rebuilt the hoe as i had nothing to hold onto when getting up and down of the seat , and as you said its handy when your up there too having a look over at the excavation.
When I split the tractor I will look at adding support to the sub frame from the front to rear as you mentioned.
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2025 New/Unused Min Skid Steer Loader (A51573)
2025 New/Unused...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
Freeman Bros 200 Gallon Fuel Tank (A51573)
Freeman Bros 200...
