Yanmar 165D oil pressure sender
   / Yanmar 165D oil pressure sender #11
Huh? This is the oil pressure sensor. Not related to overheating.
I found it un-nerving to drive back to the barn with the oil warning light glowing even though I knew I had ripped the sensor off like Millard did. Aside from that anxiety there is no harmful effect from running with it broken so long as you aren't losing oil there.
The replacement I got at Autozone was specified for some 20 years of Subaru models plus various Datsun, Toyota, Mazda, Mitsubishi, etc etc.
Screw or blade wire attachment is the only thing to watch for. If it looks about right and the right threads, then you've found the correct one. Yanmar used a lot of stuff also supplied to Datsun by the outside manufacturer - everything electrical, radiator cap, etc, for the Yanmars of the 70's.
I wasn't focused on overheating. Heat raises pressures too. And the pressure can be raise if the engine block vent tube is plugged some.
Simple fix. Got the part from Walmart suprisingly.....light works too
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53472)
2015 RAM 5500...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
