Yanmar 1602D starting issues
   / Yanmar 1602D starting issues #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
I don't generally use my tractor during the winter months, but the fellow who cleans my driveway is missing in action.
I went to start my tractor yesterday, and after cycling the thermostart, it turned over but didn't quite start. I stopped cranking it for a couple of minutes and when I went to re-crank the engine, nothing happened. The dash lights went off. Since the battery was older, I decided to charge it for the evening and the same thing happened this morning.
Next step, I replaced the battery and tried again. Same thing.
I check the power at the solenoid with the key turned to crank and there was no voltage (bad key switch?). I did have dash lights and a thermostart light.
I then tried to by pass the key switch, and saftey switchs by momentarily powering the solenoid (it clicked, but no start and everything now appears dead.
I assume I have must have burnt the fusible link? I don't know what to try now or where to start.
Battery is good, connections to battery and solenoid are good.
Please advise.
Regards,
Rob
   / Yanmar 1602D starting issues #2
I would double check all battery, starter, connections, and especially where the ground wire goes to the frame. You have classic symtoms of a bad connection.
   / Yanmar 1602D starting issues #3
Is the battery any good that you swapped around? In the original post you stated
( I went to start my tractor yesterday, and after cycling the thermostart, it turned over but didn't quite start.) That is a good sign that the electrical was intact at the first testing. You need to have the engine on a block heater, or lower rad hose or a big 300 watt heat lamp. Charge the good battery. I think you have introduced a bad connection to the follow up of the first weak turn over As stated by winston1.
Craig Clayton
The 2nd Battery is brand new. I think I am going to replace both battery cables as they are a pain to do anything with when the FEL is on (can't open the hood all the way), then I'll be 100% sure they are good.
Does anybody know where the fusible link should be located?
   / Yanmar 1602D starting issues #5
Forget the fusible link, it's in the starter switch circuit which you bi-passed. Go back to bipassing everything but the starter. Hook jumper cables directly to the starter and see if it starts. Does your volt/ohm meter tell you that all of these connections are good? You said the sol clicked but would not start. It can't start unless the starter turns, did it?
When I tried to trip the solenoid with a jumper, it clicked but the starter did no spin. After doing this everything went dead.
To clarify:
I suspect the original battery was fine.
I was not getting a voltage from the key to the solenoid, but I did have power elsewhere.
I then tried powering the solenoid directly, the solenoid engaged but the the starter didn't spin and now I don't seem to have power anywhere.
I have pulled the starter and will bench test it to make sure there is no issue. I will then work through the battery cables to make sure they are all fine. And then check the ignition switch and clutch switch.
Anything else to check?
   / Yanmar 1602D starting issues #7
I had a similar problem recently. I went to start it. Didn't crank it long enough.. turned the key again... nothin'.. no click even. The cables looked iffy. If original, they're 24 years old. They can corrode under the insulation. I installed new cables, ground the frame where the ground connects, & used a longer bolt. Done. It may well've been a bad ground, however, it was time for cables anyhow. I'd start by taking the ground off & cleaning the cable end & frame.
   / Yanmar 1602D starting issues #8
Sounds as if you have multiple problems. If the sol clicks, but starter does not turn, bad sol or starter, assuming, as you say, good battery (BTW exactly how many volts are in your battery?). If you eliminate the starter and connections, bypass the clutch safety switch.
   / Yanmar 1602D starting issues #9
Before pulling off the starter, I'd suggest doing the battery cables. At the least, pull them all off, then thoroughly clean the connections on the battery and tractor ends. It is the easier fix, and is more likely the problem anyway.
You've already pulled the starter, so testing is only wise, but do the battery cables and their connections. I know you said they're good, but unless you have a way to put a serious load on the cables, you can't really verify that. The fact that the solenoid clicked with a jumper wire means there wasn't enough power getting to the starter. The fusible link to the solenoid shouldn't affect the large cables. I would expect your issue to be in the battery cables or their connections, based on what you've said.
Does the 1602 have a PTO safety switch? The first tractor I encountered with one of those drove me nuts before I figured it out.
Others have given the same and good advice, I think. Make sure to let us know how it turns out!
so far,
the starter solenoid will click, but actually doesn't move enough to engage the gear or complete the circuit for the starter.
   / Yanmar 1602D starting issues #11
Do you currently have the starter off the tractor? If the solenoid only clicks, you have found at least a part of your trouble. Have you verified the battery has over 12 volts? As Norm and others have said, you may have a bad solenoid, and a connection issue as well.
You're homing in on the issue. Keep with it. Check the fusebox, as well, for your other electrical issues. If you've lost power to the rest of the tractor, start easy and work your way through it.
   / Yanmar 1602D starting issues #12
so far,
Are you futilely attempting to repair this tractor without a volt/ohm meter:confused:? How much voltage is in your battery?
   / Yanmar 1602D starting issues #13
Thats a must. The same thing was going on with my starter. After I disasembled it Blew and cleaned the Brushes and Dust out it's been fine for 3yrs.And my Throw Out Gear was Sticking Also And Not engaging the Fly wheel. A little Steel Wool and oil took care of that ;)
Carey
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
