yanmar 1500d amp meter
   / yanmar 1500d amp meter #1
turnerbend
Rome, Ga.
Yanmar 1500
HELP! When connecting an amp meter on this tractor, do you connect the + (pos) to the battery + (pos) and the - (neg) to ground or what? Need a simple wiring diagram....
   / yanmar 1500d amp meter #2
If your using the amp meter to monitor your charging system, it would be wired as so.....
   / yanmar 1500d amp meter #3
The alternator output on these things is so pitiful (approx 4 or 5 amps max on the 1500) that it won't show much on standard automotive ammeters, typically +/- 30 or more amps full scale. I put a voltmeter on mine and find it more useful. Did you find an ammeter with a lower scale? I wouldn't mind changing mine.
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
1240 (A50490)
1240 (A50490)
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
