yanmar 1500 pto
   / yanmar 1500 pto #1
james waters
whitesville,ny
yanmar 1500
hi everyone. on my 1500 I cannot get the pto to stop . it will only stop when
I step on the clutch. any info on this and how the pto operating lever is suppose
to work would be great.
thanks
jim
   / yanmar 1500 pto #2
More info needed. What happens when you put it in neutral? Is there an implement attached?
   / yanmar 1500 pto #4
Does the PTO continue to turn in neutral when it is under a load? It could just be spinning because of the friction in the gearbox and will stop if it gets any resistance.
   / yanmar 1500 pto
I have no implements for it. and with the decal above I will check it out. I tried to stall it with my foot and I cant. but I will try again in the neutral position. I thought it was just a 2 speed pto and I could not stop it in the center position. will post again. thanks
   / yanmar 1500 pto
I could not get the pto to stop. So I got to forcing the lever stalled the tractor now the pto is stopped and when I step on clutch and engage it. It stalls the tractor. And I was off the tractor with it idling and moved the lever and it stalled the tractor now this is were iam at. What is behind the lever controls anyone know
   / yanmar 1500 pto
The only detent detected is placing the lever forward. Which according to the lable is position one
   / yanmar 1500 pto #8
Sounds to me like your going to dig in. I am not that familiar with the 1500 but looking at part drawings I would think removing the shifter housing #29 might let you see what is going on. Don't know that, someone may know better. TRANMSISSION_CASE_G: Yanmar Tractor Parts
   / yanmar 1500 pto
Hope I get some more feedback. I think iam going to bite the Bullitt and buy the service manual
   / yanmar 1500 pto #10
TAke the cover off. worst case you have to clean it up and put some silicone on it and reseal it.
You can pull the whole PTo off the back as an assembly, that is if its like the 2000.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
Duetz Power Unit (A50120)
Duetz Power Unit...
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
Topcat Skidloader Articulating Mower (A50774)
Topcat Skidloader...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
