Yanmar 1400 tiller and overrun clutch
   / Yanmar 1400 tiller and overrun clutch #1
Normmm
Talladega county, Sylacauga, AL
Yanmar YM2020D Satoh Beaver III Yanmar 1500
I have a Ym2020d and a 1400 (60 inch) Yanmar tiller with the short Yanmar top link. If I use the shorter overrun clutch (non quickchange type) can I use the tiller without removing the clutch from the pto shaft.
   / Yanmar 1400 tiller and overrun clutch #2
I'm going to say no, because it doesnt work on mine(YM2000). I even shortened my shaft before I realized it wouldnt work. Luckily the shaft is still long enough to use.
I have been looking at this and how to remedy it. Removing the clutch is a pain, so I have decided to get a quick disconnect one. I also plan on adding about 6" to the lower mounting points of the tiller and using another(spreader) drive shaft with a shear pin and longer top link to remove the need to change the bracket. I would like to add a slip clutch too, so if it fits the same dimensions of the clutch, it should work out well...When I finally get around to doing it /forums/images/graemlins/grin.gif, I'll post some pictures.
20" Sea Container (A47384)
20" Sea Container...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
70003 (A51691)
70003 (A51691)
2006 Ocmis 125 R4/2 (A50123)
2006 Ocmis 125...
