Yangdong Y385 Siromer 304 engine breather blowing oil
   / Yangdong Y385 Siromer 304 engine breather blowing oil #1
steveroyce
kent england
siromer 304
Hi Guys we have a siromer 304 with a yangdong Y385 engine, we did a service on it and changed the engine oil and filter, now when the revs get reasonably high it blows oil up to the breather ( respirator) and it leaks out, should there be a gasket on the top of the breather, we just have a wing nut with a metal lid and no seal or gasket, it did not seem to be doing this before the oil change any ideas ?
steve
   / Yangdong Y385 Siromer 304 engine breather blowing oil #2
You are refering to the breather on the right side of the engine block? During the oil change, did you overfill it? Did you use the same type oil(I use Rotella T 15W40) Excess oil will get splashed and more will be blown out thru the breather. Thinner oil will be more easilly carried thru the breather.
we have put in 7 litres of 15w40
   / Yangdong Y385 Siromer 304 engine breather blowing oil #4
Seven liters is just shy of two gallons. Seems like a bit much.
   / Yangdong Y385 Siromer 304 engine breather blowing oil #5
And the level on the dipstick is?
from what i can see its not even showing on the dipstick now, it was about 3/4" up the dipstick when we filled it the dipstick looks like it has had something rubbing on it as it has like a wear mark on it
   / Yangdong Y385 Siromer 304 engine breather blowing oil #7
Y385 oil capacity:
5.36 quarts to be exact, you put in about 7.4.
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
