XUV850D glass cab door kit & heart failure
   / XUV850D glass cab door kit & heart failure #1
Donegal_TDI
Donegal, Ireland
SAME100.4 Kioti551C XUV855D
OK, strange title, but all will be revealed.
Was at Local JD dealer yesterday evening to collect a JD cart for my little fella for Xmas.
They told me a pallet of stuff had come in for your gator.
They loaned me their flat bed trailer to take the stuff home.
Overjoyed at this,
when home, I started taking the stuff off.
The glass kit contains 2 doors, rear opening window, various panels for sealing off cab, all in a very heavy wooden crate, very well packed.
I said to myself, best place to store the doors is hang them on the XUV.
So I removed the softie doors that came with the Gator,
and carefully carried the first glass one into the shed for fitment ensuring nothing was there to trip on in the process bearing in mind it was dark.
These doors are BIG, and heavy.
I greased the pins and very carefully mounted them on the cab.
Stood back to admire my work,
and holy cr*p(the heart failure bit),
these things are bigger than the opening of the cab.
All sorts went through my head, maybe the cab is different from the States.
Anyway, composed myself a little and the mist started to clear.
The design of these doors are new.
There are no longer any quarter lights on the front of the cab with these doors.
The door now covers the entire side of the cab.
The quarter light components of the cab simply unbolts and a new bottom closing rail bolts in it's place, for the door lock to engage on.
Haven't done this yet, just hung the 2nd door and rapidly made a coffee for a caffeine fix.
Heart failure averted.
No doubt there will be more tales like this before I'm finished.
One consolation when buying a product from a large manufacturer, parts are readily available and you can be assured that lots of R&D has gone into design of their parts.
This in itself was one of the main reasons I went JD.
End of rant.
   / XUV850D glass cab door kit & heart failure #2
Please post a couple pix of the new style door you mention.
   / XUV850D glass cab door kit & heart failure #3
I had the new door installed on my XUV and I think the larger doors make entry and exiting the cab easier. I think in the summer when I remove them the cab will be more enjoyed also.
This I will do in January.
   / XUV850D glass cab door kit & heart failure #5
Here is a link and a picture of the new style door.
Fam
   / XUV850D glass cab door kit & heart failure #6
Fam
I wish they would have made the new door with a crank down or sliding window.
   / XUV850D glass cab door kit & heart failure #7
I hate to think what the replacement cost of a door is if you break one. That's a lot of glass getting close to the ground. Not something your local glass shop can cut.
   / XUV850D glass cab door kit & heart failure #8
yea i think they could have made the doors a half/half kinda thing . to many times i had tree branchs try to swing back up on me when in the woodsi could just see it now a bunch of shattered glass all over the place. they are nice though.
You also get a redesign of the rear cab window which now semi-opens on hinges.
Also close out panel is redesigned on left of cab with a nice cover over diesel tank filler, all glass.
Still busy at work.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
198367 (A51243)
198367 (A51243)
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
