XUV Diesel Gator in Water
   / XUV Diesel Gator in Water #11
My friend has between 550-600 hrs. on his Gator 620i with original belt and clutch. It's not "mudded". But it is in mud almost daily. It has been suprisingly reliable. Last week, a front wheel bearing was replaced. But that is all!
The 620 has an enclosed clutch but the diesel doesnt. Thanks for the info.
   / XUV Diesel Gator in Water #13
In regards to the torque value of ~188 ft/lbs, that could be the torque available in low range at the transmission output. There is no way you are getting 188 ft/lbs out of a gas engine that only puts out 40/50 hp without some expensive technology. It must be the torque value after all the gear reductions. If it has a 5:1 final drive ratio that would work out about right for taking in 40 ft/lbs and putting out 188 ft/lbs while losing about 12 ft/lbs through friction and other losses. I do not even think my 1970 F350 with the 350 cubic inch motor has much more than 175/200 ft/lbs. Torque is not directly related to RPM, whereas hp equals torque times RPM divided 5252. So if torque is a constant 100 ft/lbs regardless of RPM then HP with go up directly with RPM but the reverse is not the same.
2005 Interstate StreamLine 14ft T/A Enclosed Cargo Trailer (A55973)
2005 Interstate...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
John Deere 7410 (A53317)
John Deere 7410...
flatbed trailer 24ft (A56858)
flatbed trailer...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
202476 (A54757)
202476 (A54757)
