XR4150H Hub and/or bearing
   / XR4150H Hub and/or bearing #1
obrutbaas
Black Forest, CO
LS XR 4150HC
Good Evening,
XR4150HC, purchased Oct 2016. Tonight while digging out from the blizzard here on the Palmer Divide my right front wheel bearing locked up as I was moving then broke free with the accompanying massive leak of oil and half an O ring and what looks like a bit of a shift in the wheel.
Question for you all, has anyone had a hub/bearing fixed past the 2 year bumper to bumper, i.e. under the powertrain warranty.
I did not get the entire warranty policy when I bought the tractor, at least I can't find it with my other documents. As best I can tell I have a 2 year bumper to bumper, or do I have more? Have a call in to the dealer who will be open in the morning, just thought I'd ask here.
Thanks
Stump
   / XR4150H Hub and/or bearing #2
Hi, I have a xr4046 and had a front wheel bearing failure last year. When I talked to the dealer he didn't think it was covered by the 5 year drive train warranty, but I called the corporate office and they said it was covered. I told the dealer and they fixed it under warranty, no problem and no cost to me. This bearing should be covered by the drive train warranty.
Thanks
John
Thanks John. Calling the dealer when they open and will hit up corporate if needed. Appreciate the info.
   / XR4150H Hub and/or bearing #4
I would also think that would be covered under powertrain warranty. Good luck with it and keep us posted.
   / XR4150H Hub and/or bearing #5
I just broke the steering arm, and it was covered under warranty. I dont see why a wheel bearing wouldnt be, especially since it's not that old.
Thanks. I just spoke with the dealer and it is covered by the powertrain warranty. They have another one in there now for the same thing, seems pretty common. I did also call LS corporate since they were open first and they confirmed it is a warranty item. Thanks for the replies.
   / XR4150H Hub and/or bearing #7
Always good to know. Thanks for sharing.
   / XR4150H Hub and/or bearing #8
I'd be curious to know if that bearing is of Chinese or Japanese origin.
I'd bet a beer that it's Chinese.
Not 'China-Bashing'. They make some good stuff when they want to, it's just that I think there was a bad run of bearings back in 2015-16.
   / XR4150H Hub and/or bearing #9
My tractor is the 3025H and is a 2018 model. I am having to replace wheel bearings to my final drive hub assembly in what began to be from a seal leaking bad. My bearings came from Japan and I attached a picture of the outer bearing that got to hot. IMG_6354.JPGIMG_6355.JPG
   / XR4150H Hub and/or bearing #10
NSK is supposed to be about the best there is. I think I'd let them know. seriously
There is a lot of counterfeits going around. The Dangers of Fake Bearings | Machine Design
It looks to me like that bearing 'spun'. Not sure it's the fault of the bearing itself. I could be way off, just a guess.
Did the bearing seize, causing it to then spin??
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
PALLET TOTE OF CERAMIC TILES (A58374)
PALLET TOTE OF...
Grapple for excavator (A56857)
Grapple for...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
Rhino DB150 (A57148)
(4) 225/65R17 USED TIRES (A58374)
(4) 225/65R17 USED...
