XR4150 won’t start
   / XR4150 won’t start #1
The Rock
Wyoming
Ls xr4150
Any suggestions, turn the key, it makes a whirring noise but won’t start. If it was a car I would say the solenoid was bad, but I don’t know anything about diesels.
No idiot light are showing on the instrument panel.
   / XR4150 won’t start #2
Does the engine turn over at all?
PTO switch in the off position?
Check the safety switch on the clutch?
Everything appears normal, pto is off, and with everything in neutral, clutch and brake pushed I turn the key and it whirrs, but starter never seems to engage or turnover.
Negative battery cable was loose, but I tightened that, manual suggest checking fame grounds but I have no clue where they are.
And thanks for the response
   / XR4150 won’t start #4
whirrs, like the starter is spinning and perhaps the bendix isn't engaging?
Can you try to start it and put your hand on the starter to feel it " or have someone ", may be a bad or stuck bendix.
I am pretty sure it is the starter whirring, I tried tapping on it, when I was a kid back in the 70s I couldn’t afford to get my car fixed and had to do that all the time to get the starter to engage until I had enough money to replace the solenoid.
After the whirring stops, it does click a couple of times.
   / XR4150 won’t start #7
From your description it sounds like the starter bendix is giving you problems. I'd take it off and bench test it. If that's the problem it should be under warranty.
Thanks for the assistance, called a mechanic today, he is supposed to be here on Thursday.
It was the starter, had a heck of a time finding one, but it’s on the way, should be here tomorrow.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
24in pin on excavator tooth bucket (A56435)
24in pin on...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
202477 (A54757)
202477 (A54757)
