XR4150 won’t start
   / XR4150 won’t start #1
The Rock
Wyoming
Ls xr4150
Any suggestions, turn the key, it makes a whirring noise but won’t start. If it was a car I would say the solenoid was bad, but I don’t know anything about diesels.
No idiot light are showing on the instrument panel.
   / XR4150 won’t start #2
Does the engine turn over at all?
PTO switch in the off position?
Check the safety switch on the clutch?
Everything appears normal, pto is off, and with everything in neutral, clutch and brake pushed I turn the key and it whirrs, but starter never seems to engage or turnover.
Negative battery cable was loose, but I tightened that, manual suggest checking fame grounds but I have no clue where they are.
And thanks for the response
   / XR4150 won’t start #4
whirrs, like the starter is spinning and perhaps the bendix isn't engaging?
Can you try to start it and put your hand on the starter to feel it " or have someone ", may be a bad or stuck bendix.
I am pretty sure it is the starter whirring, I tried tapping on it, when I was a kid back in the 70s I couldn’t afford to get my car fixed and had to do that all the time to get the starter to engage until I had enough money to replace the solenoid.
After the whirring stops, it does click a couple of times.
   / XR4150 won’t start #7
From your description it sounds like the starter bendix is giving you problems. I'd take it off and bench test it. If that's the problem it should be under warranty.
Thanks for the assistance, called a mechanic today, he is supposed to be here on Thursday.
It was the starter, had a heck of a time finding one, but it’s on the way, should be here tomorrow.
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
