XR4150 CODES S173 F03 AND S173 F13
   / XR4150 CODES S173 F03 AND S173 F13 #1
mred2
Platinum Member
West Alabama, USA
iseki tl3200, JD 450H dozer, LS XR4150, Genie Z34/22N lift
I am getting these two codes. I think temp sensors, but which one. I think it has 3. Runs fine, but will not regen. I hate to haul it 60 miles to dealer.
   / XR4150 CODES S173 F03 AND S173 F13 #2
S173 F03 is P242D should have solid amber light on & indicate DPF In temp sensor HI fault
S173 F31 is P242A should have solid amber light on & indicate DPF In temp sensor fault
Can't find S173 F13
I am sure you are right and it is F31. The DTF HAS 3 temp sensors. I will start by checking connections. I looked for mice, none found.
THANKS
   / XR4150 CODES S173 F03 AND S173 F13 #4
Here's the Service Manual diagnostics/repair procedures.
  • DPF In sensor - 자작 T4 - XR engine error code.pdf
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
