XR4150 CODES S173 F03 AND S173 F13
   / XR4150 CODES S173 F03 AND S173 F13 #1
mred2
Platinum Member
West Alabama, USA
iseki tl3200, JD 450H dozer, LS XR4150, Genie Z34/22N lift
I am getting these two codes. I think temp sensors, but which one. I think it has 3. Runs fine, but will not regen. I hate to haul it 60 miles to dealer.
   / XR4150 CODES S173 F03 AND S173 F13 #2
S173 F03 is P242D should have solid amber light on & indicate DPF In temp sensor HI fault
S173 F31 is P242A should have solid amber light on & indicate DPF In temp sensor fault
Can't find S173 F13
I am sure you are right and it is F31. The DTF HAS 3 temp sensors. I will start by checking connections. I looked for mice, none found.
THANKS
   / XR4150 CODES S173 F03 AND S173 F13 #4
Here's the Service Manual diagnostics/repair procedures.
  • DPF In sensor - 자작 T4 - XR engine error code.pdf
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
2012 Case IH 3408 (A47164)
2012 Case IH 3408...
Kuhn Hay Cutter (A48837)
Kuhn Hay Cutter...
2004 Jeep Grand Cherokee Multipurpose Vehicle (MPV), VIN # 1J4GW48S54C142580 (A48836)
2004 Jeep Grand...
2024 JT8 - 5' X 8' TILT TRAILER (A50459)
2024 JT8 - 5' X 8'...
Enclosed Service Truck Bed (A48837)
Enclosed Service...
