XR4145 Hard Shuttle Shifting
   / XR4145 Hard Shuttle Shifting #1
Mtnmnstr
Bronze Member
Amory MS
XR4145 & Farmall M
I have a XR4145 that I've been abusing for about 7 yrs. Been doing fair amount of maintenace as required. Recently my Fwd/Rvrs is getting stuck when I shift. I'm at a stop, clutch is in. I go to shift and the handle just flexes. After I rock back or forth it will release and I can shift.
What did I do this time?
   / XR4145 Hard Shuttle Shifting #2
Take the side cover off your steering column - the left side as you're looking at it from the driver station.
Follow the shift lever to the shift lever shaft. The shaft is 2 piece - 1 piece fits inside the other with a spiral flex pin to keep them tied together. That flex pin works loose and makes it difficult shifting as its hitting something in there. Eventually the pin will fall out and you will be stranded.
What I did was put the pin back in and wrapped duct tape around the shaft so it wont work free again. Probably a better solution would be a cotter pin instead of the flex pin. Get a cotter pin that fits the hole properly so the shift lever is not loose.
Thats what happened to me on my MT3 I'm not totally positive its the same setup but I bet it is. gl
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
2022 Club Car...
2011 Chevrolet Impala Sedan (A48082)
2011 Chevrolet...
2016 Dakota 410 Turf Tender Topdresser S/A Trailer (A49346)
2016 Dakota 410...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
