XR4140 Replacement Alternator Advice Needed
   / XR4140 Replacement Alternator Advice Needed #1
CobaltSky
Peyton, CO
LS XR4140HC
Recently my alternator went out on my 2016 tractor. Appears to be internally grounded. (Drained a battery and starts smelling then actually smoking as soon as a new battery is connected, before starting.)
Part number is 40266110. It is a 70amp. I'm having trouble sourcing a replacement at a reasonable cost.
Searching for part numbers online yields tons of alternators, none that have the proper oval female connector. It looks like the new part number might be 40332676, I found 2 sources for that online, but running about $400. Seems steep for a little 70amp alternator!
I did contact my dealer but they are slow to respond and may have changed ownership, also not physically nearby. I'm wondering if connections could be modified to fit any other model alternator.
Any ideas on how I should proceed would be welcome!
   / XR4140 Replacement Alternator Advice Needed #3
You could try taking it to a rebuilder and maybe save some money by having it fixed instead of replacing it. But if it was smoking, it might be too far gone to rebuild. Might be worth at least having them look at it.
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
7021 (A55851)
7021 (A55851)
159115 (A60430)
159115 (A60430)
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
