XR4140 Replacement Alternator Advice Needed
   / XR4140 Replacement Alternator Advice Needed #1
CobaltSky
Bronze Member
Peyton, CO
LS XR4140HC
Recently my alternator went out on my 2016 tractor. Appears to be internally grounded. (Drained a battery and starts smelling then actually smoking as soon as a new battery is connected, before starting.)
Part number is 40266110. It is a 70amp. I'm having trouble sourcing a replacement at a reasonable cost.
Searching for part numbers online yields tons of alternators, none that have the proper oval female connector. It looks like the new part number might be 40332676, I found 2 sources for that online, but running about $400. Seems steep for a little 70amp alternator!
I did contact my dealer but they are slow to respond and may have changed ownership, also not physically nearby. I'm wondering if connections could be modified to fit any other model alternator.
Any ideas on how I should proceed would be welcome!
   / XR4140 Replacement Alternator Advice Needed #3
You could try taking it to a rebuilder and maybe save some money by having it fixed instead of replacing it. But if it was smoking, it might be too far gone to rebuild. Might be worth at least having them look at it.
More info coming soon! (A48082)
More info coming...
2019 Ford F-450 4x4 Extended Cab Liftmoore 2550 Crane Service Truck (A46683)
2019 Ford F-450...
2013 Kia Optima SXL Sedan (A46684)
2013 Kia Optima...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A45678)
2019 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
1983 US Air Force 10,000lb Rough Terrain Forklift (A46683)
1983 US Air Force...
