XR4140 making unsettling PTO noise
   / XR4140 making unsettling PTO noise #1
strantor
Platinum Member
Brazoria co., TX
LS XR4140H
Hello,
My I have owned my brand new XR4140 just a couple of months, and I have never used the PTO. I got curious about PTO RPM for a PTO generator so I turned on the PTO for the first time, just to take some RPM measurements with a handheld tachometer. The PTO is making some unnatural noises which has me concerned. I struggle to describe the noise but it's like a random sound that occurs anywhere from every 1 second to 30 seconds and sounds like something in the realm of a tap, a bang, or crunch. I don't know what's inside there so I couldn't accurately guess, but sounds like maybe a loose bit of something is floating around in there and occasionally getting tossed around by the spinning clutch? I've heard hydraulic systems make similar sounds when there is air in the pump or other other components, however it's my understanding that the hydraulics in this case only engage/disengage the clutch, and from there it's mechanical power transfer, so I don't see why there would be flowing fluid making this noise.
Has anyone else experienced anything like this with brand new LS tractors? Should I be worried, or is this just part of "breaking in" a new tractor?
   / XR4140 making unsettling PTO noise #2
I would guess you have checked the hydraulic fluid levels and it is full and removed the plastic PTO shaft cover. Try raising and lowering your 3 pt several times to work out any air that may be in the system. If that doesn't solve the problem and it is only a couple months old and may be an inconvenience for you, take it back to your dealer. The PTO making noise is not normal on your new tractor.
   / XR4140 making unsettling PTO noise #3
I have not heard any strange noises using the PTO on my XR4155 but it was powering my Ford 917 flail so I am not sure I could have heard it anyway
If I get a chance I’ll fire up the PTO without a load and see if it makes any odd sounds
   / XR4140 making unsettling PTO noise #4
Take it back to the Dealer or at least talk to him now. It should not be making that noise my PTO dont and i have over 15 hrs on it now and my tractor is new also
   / XR4140 making unsettling PTO noise #5
Hello,
I was going to ask the same thing George asked in reference to the plastic PTO cover.
Sorry, I didn't realize I had replies to this post. Didn't show up for some reason. Yes, the plastic cover was removed. I was putting the tach up to the PTO shaft to measure RPM.
   / XR4140 making unsettling PTO noise #7
Though no unsettling noise should be coming from your PTO, without hearing it, it would be hard to diagnose. Can you post a quick video of it? What did the tach say? If you grab the shaft, can you wiggle it up/down, left/right, in/out?
I did try to make a video but my phone would not pick up the sound like the ear does. The shaft was firm when I grabbed it , no wiggled. The RPM was right on 540 when I had engine RPM at the green line.
I dropped it off at the dealership today and will see what they say.
Yesterday when I dropped it off, before I left I turned on the PTO and it wasn't making any noises. This morning I get call saying they could find anything wrong with it. Figures.
   / XR4140 making unsettling PTO noise #10
Self correcting problem! I like those!!
Until they come back.
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2021 TAKEUCHI TL8R2 SKID STEER (A51242)
2021 TAKEUCHI...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
