XR4100 series hydraulic top link?
   / XR4100 series hydraulic top link? #1
dstriplett
NC
LS XR4145
Any on you guys replaced the mechanical top link with hydraulic top link? Do you happen to recall the setup specs? Hoses/couplings/cylinder specs etc? Finding technical info for LS tractors is way more difficult than it should be in my opinion -- especially when your local dealer goes belly up.
   / XR4100 series hydraulic top link? #2
I provide a 2 1/2" dia cylinder with a 1 1/2" dia rod. Working lengths can be cat 1 @ 17"-23" or cat 1-2 at 19"-27" for the 55hp unit. Hose kit has 30" & 36" hoses with 1/2" male AG type couplers. A set of flow restrictors to make adjustments slower and smoother.
Find something close to that and you should be all set.
Now I did just come across an odd requirement, but something was different with his draft links for some reason. :confused:
   / XR4100 series hydraulic top link? #3
I replaced mine with same system I got from Brian years ago for my Kioti. Works very well.
   / XR4100 series hydraulic top link? #4
+1 for Fit-Rite.
Brian .. not only builds them .. he uses them!
   / XR4100 series hydraulic top link? #5
I too was trying to save money on mine. This is what I have used pretty hard for 500 hours, works great for me.
All from agrisupply
90599 TOP LINK CYL CAT 1, 20-28" 1
18653 3/4"ADJ. ORB X 1/2"FEM. PT hyd fitting x 2
86668 1/2" X 24" HYDRAULIC HOSE x 2
86641 1/2-14 NPTF QUICK COUPLER W/BALL VALVE MALE 8GPM x 2
It was $215 shipped for me and have been worth every penny.
Hydraulic side link is from "CWA" on amazon. This is the description:
2 1/2" Bore x 4" Stroke x 1 1/2" Rod, 3000 PSI, SAE 8 Port Weld Clevis Cylinder
I did have to cut one side off the cylinder and one side off my factory side link and weld them together. But for less than $100 it was a no brainer. This setup has held up for me. YMMV.
   / XR4100 series hydraulic top link? #6
All from agrisupply
How does your setup work without the flow restrictors Brian recommends?
   / XR4100 series hydraulic top link? #7
Never knew anything about it. "make adjustments slower and smoother" I can live without that for the kind of money im saving (or potentially add it for cheap?)
Thanks for all of the replies folks. Very useful info.
2017 Caterpillar 326FL Hydraulic Excavator (A55787)
2017 Caterpillar...
Margaritaville Decorative Sign (A55758)
Margaritaville...
2001 Dodge Durango SLT (A53314)
2001 Dodge Durango...
40' CONTAINER (A51244)
2007 John Deere HPX Gator 4x4 Utility Cart (A55787)
2007 John Deere...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 4x4...
