XR41 Series 3Pt Control Lever Friction Adjustment
   / XR41 Series 3Pt Control Lever Friction Adjustment #1
KP2654
LS XR4150
The 3 pt control handle on my XR4150 is very loose and will not (due to engine vibrations) stay in place when the implement is lifted completely up. If I don't hold it up, it will creep down and lower the implement. Any idea how/where to adjust the friction on the handle/lever to keep this from happening?
   / XR41 Series 3Pt Control Lever Friction Adjustment #2
Follow the handle down to the transmission. You should see the friction discs, a big spring and two studs with a nut and a jam nut behind.
You can adjust as needed there.
   / XR41 Series 3Pt Control Lever Friction Adjustment #3
I was just looking at the service manual for this question, but ptsg beat me to it. The friction plates are in that pack, on the outside rear of the tractor where the cables hook up. You might have an external control lever there too.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A55315)
Magnolia Trailer...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
