XJ202H Pressure relief valve
   / XJ202H Pressure relief valve #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Has anyone bumped up there pressure relief valve yet to get alittle more lift capability, I'm thinking of doing it to mine but would like to get a gauge on it first to see where I'm at and not to increase it to much,
   / XJ202H Pressure relief valve #2
Look through above the RH rear tire. Behind the PTO selector lever you will see a squarish box that has an allen head screw and a lock nut protruding from it towards the rear of the tractor. The backhoe would likely block access from the rear. Loosening the lock nut and turning the screw inward will increase the pressure. Spec is 2133 PSI. Using the loader valves, the spec on the connectors is ISO-7241-A 3/8. You will see that there is also a similar type of adjuster below the loader valve.
Great information thank you, is the hydraulic line in the back that feeds the backhoe and then couples togethor the same connectors as the front loader ones also
   / XJ202H Pressure relief valve #4
On mine it is not as my hoe is plumbed in via a set of remotes.
WESSEX RMX500 LOT NUMBER 44 (A53084)
WESSEX RMX500 LOT...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
