XJ202H Pressure relief valve
   / XJ202H Pressure relief valve #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Has anyone bumped up there pressure relief valve yet to get alittle more lift capability, I'm thinking of doing it to mine but would like to get a gauge on it first to see where I'm at and not to increase it to much,
   / XJ202H Pressure relief valve #2
Look through above the RH rear tire. Behind the PTO selector lever you will see a squarish box that has an allen head screw and a lock nut protruding from it towards the rear of the tractor. The backhoe would likely block access from the rear. Loosening the lock nut and turning the screw inward will increase the pressure. Spec is 2133 PSI. Using the loader valves, the spec on the connectors is ISO-7241-A 3/8. You will see that there is also a similar type of adjuster below the loader valve.
Great information thank you, is the hydraulic line in the back that feeds the backhoe and then couples togethor the same connectors as the front loader ones also
   / XJ202H Pressure relief valve #4
On mine it is not as my hoe is plumbed in via a set of remotes.
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
Loftness Mulching Head (A51573)
Loftness Mulching...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
