XJ2025h with Backhoe - hydro config
   / XJ2025h with Backhoe - hydro config #1
jdom84
Montana - the frozen north
LS xj2025h
I'm curious to know how others or their dealers connected the backhoe to the tractors hydraulics for those who have the same configuration. FEL and BH
I assumed the backhoe would have been connected to the tractor via an optional quick connect remote valve kit but instead I see hoses running from different places on the back of the tractor. I also read here on this LS forums that when disconnecting the backhoe, you have to connect the 2 quick connects together which is not mentioned in the manual. I haven't removed my backhoe yet but this seems like a very odd way to hook up auxiliary implements that needs hydros.
   / XJ2025h with Backhoe - hydro config #3
I think the only other option would be a detented remote. I'm not sure what good a detented remote is on a SCUT.
   / XJ2025h with Backhoe - hydro config #4
My dealer hooked it up through a rear remote kit.
this is what i got... 1 hose from the pressure relief valve and 1 from the front loader valve. might have to make a bracket and figure out a cleaner solution or i might get the rear remote option.
This video of a BX23S at 7:17 is pretty much how mine is, just no flat face connectors. You do connect up two of the connectors on the tractor.
New Sub-Compact BX Tractor - YouTube
looks like the mt125 has some nicer features and although i would never mow with my backhoe attached, it does seem handy that everything can be attached at once with out issue. Do the 3 point arms stay on also?
   / XJ2025h with Backhoe - hydro config #7
I would not recommend mowing with the backhoe attached, though we have done it some. The 3 point lift arms do not stay on with the backhoe attached. It seems like a backhoe would have to be really far back for that to be possible. I have not actually attached my lift arms yet.
   / XJ2025h with Backhoe - hydro config #8
I just remembered that I took this picture of the connectors just before taking them off.
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
LOT: (9) Sets of Gutter Broom, 250 KP, Std 26 (5 SEG) (A59076)
LOT: (9) Sets of...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
