XJ2025H oil dipstick won't stay in.
   / XJ2025H oil dipstick won't stay in. #1
Loco539
Woodland, Wa
Ls XJ2025H
Anybody else seeing this? After working for a few hours betwen 1500-2000Rrpm when checking the oil the next day the dipstick is floating loose in the hole. Seems to be a pretty loose rubber fit.
About 20 hours on the tractor now and notice this every few days of use. Oil came filled about 3/16 above the full line.
Will locate the breather and see if any obstructions.
Thanks.
   / XJ2025H oil dipstick won't stay in. #2
I just got my XJ2025H this past weekend and have about 10 hours on it so far. I checked the oil Sunday morning and the dip stick appeared to be fully seated before I pulled it out. I'll keep a close check on it and report back if I have issues also.
Jim
   / XJ2025H oil dipstick won't stay in. #3
For the dip stick coming out I just hook the top behind the cowl and this keeps it in place.
   / XJ2025H oil dipstick won't stay in. #4
I just found the same issue this past weekend at about 70 hours. I re-seated the dip stick and checked it again that evening after using it all day digging stumps and the dip stick had popped back out again. Hooked it behind the cowl like Blue Me suggested and have not had anymore issues.
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
