XJ2025H not enough lift strength
   / XJ2025H not enough lift strength #41
If your right hand cylinder seals are bad the fluid is bypassing pressure internally in the cylinder. Could be the issue. Test it by raising the FEL a foot or so from the ground, remove hoses on the suspect cyinder & plug both ports & the hoses. The you can lower the FEL (not running the engine). If it lowers down then you know the cylinder is bypassing.
2016 CATERPILLAR 745C WATER TANK (A60429)
2016 CATERPILLAR...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2019 CATERPILLAR 299D3 XE SKID STEER (A60429)
2019 CATERPILLAR...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
CATERPILLAR OFF ROAD WATER TRUCK (A60429)
CATERPILLAR OFF...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
