XJ2025H Light Bar and Toolbox
   / XJ2025H Light Bar and Toolbox #1
Plas62
Hogansville, GA
LS XJ2025H
I recently completed the installation of forward and rear facing 20" light bars on my XJ2025H along with upgrading the tool box on my tractor. I thought I'd post some pic's of the build and the finished product.
The light bar were these from Amazon. LightFox 20'' inch 126W Cree LED Light Bar Offroad 4wd Spot FLood Combo LED Work Lights for Trucks Suv Atv Tractor Pickup Jeep Lamp 12v 15000LM
I bought the switches at Online Components.com. The switches are 20 amp dpdt by Carling Technologies. One switch is used for the lights, up position front light and down position for the rear light. The second switch I installed is for a future project. The switches fit the existing 22mm x 44mm cutouts in my dash panel perfectly. They are ran directly to the battery with 14 ga wire and I fused the circuit for 10 amps.
Though I'm sure all will not agree, I choose to drill a hole in my ROPS and run the wire through it and added a water tight cord grip.
Below are the links to the switches and fuse holders that I used.
Switches http://www.onlinecomponents.com/carling-technologies-l26d1s001azz00000.html?p=17011408
Fuse Holders http://www.onlinecomponents.com/bussmann-eaton-hhr.html?p=10809626
Pic of switches installed.
For the mounting of the light bars to the ROPS I used a 9" x 22" piece of steel plate and had a bracket and cover made from 12 ga steel. I wrapped the ROPS in a piece of rubber to reduce any vibration and ensure a good tight fit. In the final assembly the cord gip is centered in the hole and the plate is centered on the ROPS.
A couple of pic's of the completed install.
In addition to the light bars I also upgraded my toolbox. I added a mounting plate to accommodate the larger tool the I picked up at TSC.
   / XJ2025H Light Bar and Toolbox #2
Nice work, looks good! You got a nice little setup there with that Tractor. Is that a 3rd function? Where did you get it?
Thanks,
Yes it is a WR Long 3rd function remote. I ordered it with the tractor and had the dealer install it.
   / XJ2025H Light Bar and Toolbox #4
Looks great! It looks like a nice rugged build. You can probably light up the whole world with those lights! I couldn't believe it when I first put LEDs on mine.
Thanks Billrjr, They are bright and have increased my seat time. I was out working last night till about 8p.m.
   / XJ2025H Light Bar and Toolbox #6
Plas62, I need a favor :) can you take one million pictures from the backhoe showing the structural components? I almost completed my grapple and I think the next project would be a backhoe. And I have no clue where to find one near me. Pretty plz???:dance1::dance1::dance1:
Polemidis - I'm sorry, but I'm not going to be able to help. Back in September I took a new job in New Mexico and sold the tractor and my property in GA. Good Luck with your project.
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
UNUSED FUTURE AP680 HYD BREAKER HAMMER (A57193)
UNUSED FUTURE...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2021 Versatile 405 Tractor (A53485)
2021 Versatile 405...
