xj2025h lifting stuff with home built SSQA pallet forks
   / xj2025h lifting stuff with home built SSQA pallet forks #11
My steel rack started life as a man lift for a forklift. I guess that's still what it is but it gets used pretty sparingly. I've yet to figure out how to build enough steel racks that doesn't cost a fortune. I'm building another 4 rick steel rack that fits the back of my truck.
Worked on the pallet forks again last week for a bit...
Added 8lbs more steel to each of the forks. basically created a double I-beam or box beam
rust protection via the rustoleum safety blue and some D rings for picking up stuff.
   / xj2025h lifting stuff with home built SSQA pallet forks #13
Good looking unit. The blue is a nice touch.
I still need to figure out what it can lift. I stacked another pallet 40"wide by 48" long by 36 tall with a bunch of lumber scraps from my brothers construction company, picked it up just fine and it was heavy because square wood stacks tighter than round/split wood. I noticed the hydro-static steering would not move at a dead stop like others have mentioned on the bigger tractors. I then decided to go try and lift the 48" pallet of split wood and I could lift it 3-4 feet off the ground where as last week i couldn't lift it at all.
   / xj2025h lifting stuff with home built SSQA pallet forks #15
Mine has not had steering issues with a load. I do wish it would lift more though.
   / xj2025h lifting stuff with home built SSQA pallet forks #16
My LA524 loader which has a similar rating as yours can lift a thousand pounds of concrete 4 feet high but no higher. Keep in mind load placement makes a big difference.
I did cheat a bit... When I first got the tractor, I was unhappy with the FEL/loading the bucket to full performance, so I adjusted the relief valve half a turn. Made it much more capable at FEL work and so far been very happy with what I've able to pick up with the pallet forks.
   / xj2025h lifting stuff with home built SSQA pallet forks #18
Where are the relief valves located?
   / xj2025h lifting stuff with home built SSQA pallet forks #19
The valve that you adjust is located on the RH of the transaxle near the top, viewed from the rear. You'll see a block with allen headed screw with a lock nut on it.
   / xj2025h lifting stuff with home built SSQA pallet forks #20
A very nice build
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2020 DRAGON ESP...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
