XJ2025H Front axle leakage
   / XJ2025H Front axle leakage #1
tomplum
Elite Member
PNW
XJ2025H
I've seen bits and pieces on the forum on these and different makes that the front axles leak at the breather and fill caps. I've been keeping it in the mid safe zone on the stick. Ours will do this intermittently. I can't hardly think that new caps will correct the problem. Am I wrong? Has anyone or their dealer tried a different viscosity fluid? :confused3:
As time has gone on, what I see is that the oil level drops down mid-way in the safe zone and doesn't leak anymore. Anyone else similar? Also, tire pressure 31 rear and 23 front on this TLB sound right?
   / XJ2025H Front axle leakage #3
Oil level at the midway point is correct. Overfilling may or will cause a leak,
As for tire pressures, your owners manual has recommended pressures listed based on type of tires you have.
Mine, of course is a larger tractor with larger tires and calls for 50 PSI front, 20 PSI rear using R4's. I run 45-50 front and 16 rear in mine. Higher pressures in front for loader work. Lower in rear for better ground contact footprint.
The pressures listed were what was listed in the manual. The loader manual states to use the max pressure. The fronts were 5#s off from one another , but the highest was 33 PSI. I don't recall what the tire said on the sidewall. I'll up the front pressure and experiment with the rear as well. She's been playing in the dirt with the loader, so I should up the pressure some.
2290 (A58376)
2290 (A58376)
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58216)
2012 DIAMOND C...
2201 (A58376)
2201 (A58376)
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
