XJ2025 H only has 100 hrs, chg hydro oil ???
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #1
cvcman
syracuse ny
john deere
Ok I have 108 hrs and I did the 50 hr filters chg on the hydro and the engine oil and filter..is a 2015 I bought brand new..Today chgd the engine oil and filter...
Someone said should chg the hydro tranny oil too,,thats like 5 gallons and the oil in the tranny looks brand new...isn't that a waste ??
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #2
What does the chart in your owner's manual say?
You only have 108 hours in over four years?
I have 160 in just over one year.
yea I don't use it much..I use it to move snow and brush hog,,,other than that I did use it to move stone and mulch when I built my pole barn
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #4
250 hours I think is spec.
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #5
Read your owners manual. Typically at the 50hr service, you change the hydraulic oil filter, but the oil itself is changed later.
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #6
250 is what mine said but I changed it at 50 for 'good measure'. At four years, I'd probably change it just due to possible condensation from sitting so much in constant temperature changes.
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #7
Quite often your hourly service also has a time and it is which ever comes up first.
   / XJ2025 H only has 100 hrs, chg hydro oil ??? #8
I was scrolling down to post this very thing. it will probably have some water in it, purely from the condensation. I'd go ahead and change it. you can get it at Tractor Supply relatively cheap, and regardless of cost a LOT cheaper than repairs
2015 TRANSMASTER LOWBOY TRAILER (A52576)
2015 TRANSMASTER...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
