XG3025 Wiring
/ XG3025 Wiring #1
opie1988
Tabor City
LS XG 3025
was looking around and found a two wire connection that I am not sure if it is hot or keyed power , tucked behind the bar on the gas tank. LS sells a switched light that plugs right into this but is $99.
/ XG3025 Wiring #2
/ XG3025 Wiring #3
I have a 3037. The fuse for the working lights blows out when the switch is activated. The bulbs in the grill are LED. Any ideas?
/ XG3025 Wiring #4
Try removing the connectors from the headlights and then turn the switch on and see if the fuse blows.
/ XG3025 Wiring #5
First, thanks for offering to help.
I removed the headlight connections, turned on the headlights and got an immediate blown fuse for the work lights.
/ XG3025 Wiring #6
Does it blow the fuse at the first switch setting " Hazard Lights " of only when you turn it to the headlight selection?
/ XG3025 Wiring #7
I have separate switches for headlights, hazard lights and the grill work lights. Mine is a XR 3037.
In response to your query, I had the headlight switch in off position and the individual wires to the headlights disconnected. I then pressed the grill work lights switch to "on" position and the fuse for the work lights blew out immediately.
/ XG3025 Wiring #8
Sorry, I was thinking the switch was the same on that model, your just going to have to trace the wires from the grill lights to find it.
/ XG3025 Wiring #9
I assume that you think there is a short in the wiring-a wire has been rubbed raw or some connection is crossed over to another wire or ground?
Thanks for your help.
/ XG3025 Wiring #10
It sounds like a short. Test continuity between the wire after the switch to ground with the bulbs removed. It should read open.
John Deere 185 Hydro Riding Tractor Mower (A66285)
John Deere 185...
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A65563)
INOP/NON-RUNNING...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
Linx UT357714T 14ft Trailer (A65640)
Linx UT357714T...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
