XG3025 Wiring
   / XG3025 Wiring #1
opie1988
Bronze Member
Tabor City
LS XG 3025
was looking around and found a two wire connection that I am not sure if it is hot or keyed power , tucked behind the bar on the gas tank. LS sells a switched light that plugs right into this but is $99.
   / XG3025 Wiring #2
   / XG3025 Wiring #3
I have a 3037. The fuse for the working lights blows out when the switch is activated. The bulbs in the grill are LED. Any ideas?
   / XG3025 Wiring #4
Try removing the connectors from the headlights and then turn the switch on and see if the fuse blows.
   / XG3025 Wiring #5
First, thanks for offering to help.
I removed the headlight connections, turned on the headlights and got an immediate blown fuse for the work lights.
   / XG3025 Wiring #6
Does it blow the fuse at the first switch setting " Hazard Lights " of only when you turn it to the headlight selection?
   / XG3025 Wiring #7
I have separate switches for headlights, hazard lights and the grill work lights. Mine is a XR 3037.
In response to your query, I had the headlight switch in off position and the individual wires to the headlights disconnected. I then pressed the grill work lights switch to "on" position and the fuse for the work lights blew out immediately.
   / XG3025 Wiring #8
Sorry, I was thinking the switch was the same on that model, your just going to have to trace the wires from the grill lights to find it.
   / XG3025 Wiring #9
I assume that you think there is a short in the wiring-a wire has been rubbed raw or some connection is crossed over to another wire or ground?
Thanks for your help.
   / XG3025 Wiring #10
It sounds like a short. Test continuity between the wire after the switch to ground with the bulbs removed. It should read open.
JOHN DEERE D105 RIDING MOWER (A51243)
JOHN DEERE D105...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2015 Peerless Tandem Axle Walking Floor Trailer (A47384)
2015 Peerless...
2022 JOHN DEERE 85G EXCAVATOR (A51242)
2022 JOHN DEERE...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
