XG3025 Delivered
   / XG3025 Delivered
doesn't feel underpowered at all. Tell the dealer to put on a 6 ft bushhog and drive it around engage it, I can hardley tell it is back there and I was cutting about 3 ft tall thick grass that my zero turn bogged down on when it was 8" tall (field grasses). check out the lift capacities as compared to other makes and it comes in around the 30-35 hp class of tractors. I was contemplating a Kioti CK3510 but this was such a better value that I pulled the trigger on the LS.
   / XG3025 Delivered #12
I will definitely do that. I'm just afraid it won't be enough of a difference from my J2023.
   / XG3025 Delivered
how big is your bucket? mine is 66" wide and the break out rating is 2K lbs of force. This is a full size tractor but not a diesel glutton. traction is usually determined by tires vs weight H.P. is plays a small part unless you are doing something that isn't recommended. I think of the tractor as tool and it fits in the tool box nicely and works when I need it. Good luck to you and your decision.
   / XG3025 Delivered #14
Congrats,
I'm looking at the xg3025 also but no dealers in Washington state carry them. They go from xj2025 to xg3135 which is $4k more. Keep us up to date on hours and take pictures of some of the chores you use it for.
   / XG3025 Delivered #15
Absolutely! I'd like to see and hear what kind of tasks and jobs you're able to do with it.
   / XG3025 Delivered
I have some stumps to round up tomorrow, weather permitting. I will take some pics.
   / XG3025 Delivered
I pulled a few 4x4 posts out of the ground (concreted) but I got rained on for the last 2 and couldn't take pics tomorrow should be a better day.
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD-78HF...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
Liebherr L542 Articulated Wheel Loader (A55851)
Liebherr L542...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
