X738 ruff start
/ X738 ruff start #1
4runner1
redhook ny
john deere
I have a new 2013 J.D. x738 On cold start the engine runs ruff and misses for the first 4-5 minutes .Once warm it runs fine.
I had a 2003 X585 with the same engine that never had this problem. Nothing like spending thousands of dollars to buy problems.. Has anyone else experience this problem with the Kawasaki engines.
/ X738 ruff start #2
First, welcome to TBN. Sorry you're having issues.
Contact your selling dealer; sounds like the cold start circuit is not working. It shouldn't run rough, and certainly not for that long. Could be a defective cold start injector/circuit temp sensor, etc. Should be easy for dealer to fix under your warranty. just make sure you don't have a rodent nest in your air filter assembly, or similar. Mice can screw up anything if they find a way in.... What do you do exactly when starting it cold?
/ X738 ruff start
I follow the procedure as per the manual. Turn key on , wait till the self test lights go out and put throttle half way.
Never had any problems with my X585. I will let the dealer look at it once it stops snowing . Just finished plowing 2fee of snow from yesterdays storm. Thanks for the input
/ X738 ruff start #4
No problem! FWIW, I went to Bard as undergrad, lived in Red Hook for a while. Used to go to Foster's in Rhinebeck a lot to eat.
Tonight I got real stuck with my tractor, in the ditch and off the road. Gonna have to try again tomorrow to get out.
Where's your Deere dealer?
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
Curtis 80 Gallon Air Compressor (A65640)
Curtis 80 Gallon...
John Deere 490E Excavator (A62679)
John Deere 490E...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
