X730 - Where is this located/installed
/ X730 - Where is this located/installed #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
Owner of a used X730, found this AIR INTAKE, UPPER X7 HOOD, PN: M166252 (attached) in the driveway after blowing and based on the Parts Catalog pretty sketchy where it's installed or how it's held in place, noticed some melting on the plastic piece around what appears to be a mounting hole of sorts, I'll be purchasing a replacement. A PIC would be great, THANKS............
  • Air Intake.pdf
/ X730 - Where is this located/installed #2
It snaps into the slots on each side of the center of the hood between the hand grab & front of the hood.
Mine fell out also. After it fell out the second time, I just left it out.
Chevy, Thanks for the response, probably will also leave it out too, it mysteriously appeared in the driveway after I ran it over. Thanks again.. One note, I miss the split brakes on my 425 to brake one rear wheel or the other, that came-in handy when blowing.
