X729 or X749
   / X729 or X749 #1
jkadylak
Traverse City, MI
Kubota B2620 & John Deere 737 ztrak
I am currenlty looking at purchasing a X729 or a X749. I will primarily be using this garden tractor for mowing and blowing snow, so I don't see any need to go with a 2305. I have appoximately 5 acres of land and will be mowing about 1 acre of it. There are a lot of trees, hills and obstacles so I know I want the AWS. Also, the driveway is a little over 500 feet long with a lot of bends & turns and a steep hill. Could anyone tell me if the diesel is worth the extra money? I am mostly concerned about blowing snow. I live in Niorthern Michigan and we get a lot of snow. Does the torque offered by the diesel engine make a big difference? Also, does the diesel have a much better resale value when compared to the gas engine. The gas engine is rated at a higher horsepower (27 hp for the gas vs 24 hp for the diesel) and the gas engine is $1000 less than the diesel engine. Any input or experience with these would be greatly appreciated.
   / X729 or X749 #2
:welcome:
Go for the diesel, as they are much better on fuel intake and they are 3 cyl so quieter. Last longer than the gas too.
And as you mentioned, the resale value is higher for the above reasons.
I have both the gas fuel injected and the diesel (mine in the older 445 and the 455), but the diesel is the better of the two, hands down.
And a big plus for the AWS too. I wouldn't be without the AWS as they handle sidehills so much better and get around very near as easy as the ZTR's.
They are well built and last a long time too.
   / X729 or X749 #3
I suspect it is a personal call, both machines will work for you. I prefer the diesel engines and have had good luck with the Yanmar diesel in my 110tlb so I chose the x749. Been very satisfied with it too. Since I haven't spent equal time operating an x729 it would be hard to comment on the differences.
I will say I have been amazed how well the x749 has performed, I have a 3PH and rear 540 pto and several attachments. It does a better job with 4 to 6' implements than I would have thought. Mowing on hillsides seems very stabile and on flat areas you can mow pretty fast.
Good luck with your decision.
   / X729 or X749 #4
I have a x728 and blow snow and run a 647 tiller, and can attest to the power, it has way more power then you need with the Kawasaki Twin.
If you understand diesels and understand where to get your fuel and what additive or additives you might need, the Yanmar diesel imported from Japan is a really good motor.
I have never had a diesel so all I know is what I have read on the different tractor forums.
You will pay more per gallon for diesel fuel but the diesel uses less fuel per hour then the gasoline motor.
I only put 9 hours a year on my x728 because I don't cut the grass with it, and storing diesel fuel or leaving it in the tractor would have been something I would have to learn what works.
I use Stabil in all my lawn and garden tractors and whatever and I have never had to change plugs or work on carbs ever in the last 25 years or more.
I love this x728, its just a lot more tractor then what I thought it would be.
One thing I believe I would do if I was thinking about a diesel, is start one up when its cold out and see how long it takes to warm up, the reason I'm mentioning this is most of them are in a cold building in the winter, especially Traverse City, I used to live in Copemish.
So if you have an attached garage and it has to set for a minute or two it could smoke things up a little, anyway the Kawasaki with the electronic fuel injection, it starts instantly and you could ease it out of the garage pretty quickly where sometimes a diesel will shake a little then you have to clean it out a little, but I would bet not all of them are slow warmer uppers, but to repeat I have never had the orange can.
Hope this gives you a little more insight.
Rob
   / X729 or X749 #5
Heres a video when I tilled the back yard with the x728, as you can see it doesn't lurch at all or even grunt in virgin sod, the Kawasaki Twin just pulls hard with no effort.
Heres the video [ame]http://www.youtube.com/watch?v=Hr4SF8tEb4c[/ame]
Rob
   / X729 or X749 #6
I guess I could mention this also, I have a heater in the cab, its like a car heater.
It can be below zero with a good wind and snowing sideways and I can run the heater on low with just a shirt on and the inside the cab stays nice and toasty and the windows don't fog up.
I'm not sure what the diesel does as for what temperature it runs at or how well it circulates the water through the heater core, but I believe the diesel takes a little longer to warm up.
I have lots of tilling and snowblowing videos on my website below with the x728, we flat out love this tractor.
Also lots of still pictures.
Rob
   / X729 or X749 #7
Did I mention the Kawasaki Twin will throw the snow a good 50' and it doesn't even grunt.
Rob
   / X729 or X749 #8
Last thing here.
This is my 68 year old wife blowing snow with the x728, she loves it, and you will never need chains on ice or snow they just go.
Rob
   / X729 or X749
Thanks for the input. I am planning on getting a mid level cab with a heater too. I was looking at the glass windshield cab with soft side doors. I spoke with a dealer today and they said that if I choose the gas engine and add the heater, I should then upgrade the alternator for another $350.00 since only the diesel comes with this HD alternator. Did you need to do this? If this is needed, it might steer me towards the diesel since the cost to upgrade is actually only $650.00 when I consider having to upgrade the alternator on the gas model.
   / X729 or X749 #10
I have a 455, which is a less fancy version of the 749 (diesel).
Benefits of the diesel:
- much better fuel economy (about half the GPH of the gas version)
- longer life - should go about 3000 hours vs. 1000 or so for the Kawi
- no worries about ethanol and stale gas
Drawbacks:
- noisier
- smells like a diesel (d'oh)
- more expensive initially
What's basically the same:
- power
- cold weather starting
- amount of maintenance required
Personally, I like my diesel, which I got from my Dad. I put about 40 hours a year on it, and it seems to go forever on a tank of fuel. Would I pay an extra $1000 for it? Not sure.
Tim
New/Unused 7ft 10 Drawer Work Bench (A48837)
New/Unused 7ft 10...
PREVIEW DATES AND TIMES (A48837)
PREVIEW DATES AND...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
2017 Dodge Ram 4500 4x4 Crew Cab Reading Service Truck (A48081)
2017 Dodge Ram...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2012 INTERNATIONAL TERRASTAR SFA 4X2 SERVICE TRUCK (A50459)
2012 INTERNATIONAL...
