X590 break in period
   / X590 break in period #1
varmintgitter
X324
Just purchased a new X590. Is there a break-in period for these tractors? If so, when should the first oil change take place? Thank-you in advance.
   / X590 break in period #3
FYI: Most manufacturer's want you to vary engine rpms often during break in period.
Ok. Thank-you for the info. I asked because the Operator's Manual does not explain this. Under Service Intervals, the mention changing the transaxle oil & filter after 50 hours, but no mention of the engine oil. However, to your credit, tomplum, the online manual does indeed mention changing the engine oil & filter after 8 hours for proper break-in.
CobyRuipert, I can't find anything about varying the engine rpm's during the break in period. However, like most gasoline engines, varying the engine's rpm's is recommended. If you find anything on this please let me know. I already mowed once with it. Put around 1.2 hours on it.
KUBOTA M4900 UTILITY SPECIAL TRACTOR (A51247)
KUBOTA M4900...
2023 LMC M30018 LOT IDENTIFIER 193 (A53084)
2023 LMC M30018...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2008 Ford F-250 (A53472)
2008 Ford F-250...
SORKO MC19-10 LOT IDENTIFIER 136 (A53084)
SORKO MC19-10 LOT...
