X540 tail lights
/ X540 tail lights #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
Hi all,
has any one added tail lights to their X5** series of tractor? I never paid any attention during the summer but noticed today that there are no tail lights on these and when plowing snow in the dark by the county road tail lights would be nice.
Can I just tap into the head light circuit or will this over load the light switch circuit?
Should I use the head light switch to power a relay and then draw power direct from the battery through the relay and fuse assembly? Probably safest solution.
TIA
/ X540 tail lights #2
Also seems you would want flashers for anything near traffic at night... even then it is risky.
Tap in where you find power on when switch is on. If it is overload, will just blow the fuse and you can update from there with a second fuse and switch.
/ X540 tail lights
beenthere,
agree on the risk but I usually just turn around and clean the end of the drive at the county road. Problem is people don't slow down just cause they can't see through blowing snow so some lights would be better than nothing that I currently have.
/ X540 tail lights #4
I don't see any problem with just tapping into the headlight circuit.
/ X540 tail lights #5
If you get a set of trailer lights in LED from an auto parts store the current draw will be minimal and yes you can attach it to the headlights or use a relay and a switch if you don't want to always have the headlights on when using tail lights.
/ X540 tail lights
thank guys,
I just have to figure how to run the wires and keep them away from the tire chains and other moving parts.
/ X540 tail lights #8
Go to just about any bike shop and buy a clip-on-light. Clip it on your collar or back of your hat. This one is a 2 watt LED with adjustments for flash speed and brightness. And it is USB rechargeable.
Cygolite Hotshot 2W SL USB - Bike World
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2015 Vermeer D9X13III Directional Boring Machine (A59228)
2015 Vermeer...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
