X540 Mulching Kit BM20827
   / X540 Mulching Kit BM20827 #1
BBO
N. GA
LX188/445/755/X540
I just bought a used X540 mower.
The PO had installed this mulching kit with M145516 blades.
I planned to take this off but seen the kit cost about $225.
So I decided to try to mow with it.
It 1st left stems of grass, but I determined the front of the deck was way too low; I have this fixed.
I have mowed 2 times with this & I am amazed at the result.
I have not mowed any real high grass, but this thing totally eliminated the clippings.
Except for a small row on the right side it's like all the grass disappears!
The mower had only 138 hours, but he had 2 extra sets of blades.
1 of the sets is worn to a rounded nub; about the worst I have ever seen.
My question is this.What is the down side of using mulching blades?
Do blades need sharpened every 3 months?
Is this mulching action stressing the belt, spindles, pto, engine etc?
The mower seems to have no problem handling the grass...
I am just trying to decide about keeping this mulching setup on.
It's NOT just different blades.
This kit has closed in baffles under the deck, and the outlet is obviously blocked.
I see the Exmark professional zero-turn mowers with mulching setups mowing early in the AM with totally wet grass. I have tried mine in wet grass and it also seems to mow with no problem.
I thought it would be clogged up bad underneath after wet mowing.
But when I used the water hose attachment afterwards, almost nothing washed out!
   / X540 Mulching Kit BM20827 #2
Well it sounds like you have lucked out and got a good deal. Now if you could just manage to hang on if one of your front tires blow while mowing at high speed!
I would not use water to clean the deck. You are just inviting rusty bearings.
Richard
1261 (A50490)
1261 (A50490)
John Deere 870 (A50120)
John Deere 870...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2001 Fontaine 35' Detach Trailer (A50121)
2001 Fontaine 35'...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
EZ-GO Freedom SE Electric Golf Cart (A50121)
EZ-GO Freedom SE...
