X540 Mulching Kit BM20827
   / X540 Mulching Kit BM20827 #1
BBO
N. GA
LX188/445/755/X540
I just bought a used X540 mower.
The PO had installed this mulching kit with M145516 blades.
I planned to take this off but seen the kit cost about $225.
So I decided to try to mow with it.
It 1st left stems of grass, but I determined the front of the deck was way too low; I have this fixed.
I have mowed 2 times with this & I am amazed at the result.
I have not mowed any real high grass, but this thing totally eliminated the clippings.
Except for a small row on the right side it's like all the grass disappears!
The mower had only 138 hours, but he had 2 extra sets of blades.
1 of the sets is worn to a rounded nub; about the worst I have ever seen.
My question is this.What is the down side of using mulching blades?
Do blades need sharpened every 3 months?
Is this mulching action stressing the belt, spindles, pto, engine etc?
The mower seems to have no problem handling the grass...
I am just trying to decide about keeping this mulching setup on.
It's NOT just different blades.
This kit has closed in baffles under the deck, and the outlet is obviously blocked.
I see the Exmark professional zero-turn mowers with mulching setups mowing early in the AM with totally wet grass. I have tried mine in wet grass and it also seems to mow with no problem.
I thought it would be clogged up bad underneath after wet mowing.
But when I used the water hose attachment afterwards, almost nothing washed out!
   / X540 Mulching Kit BM20827 #2
Well it sounds like you have lucked out and got a good deal. Now if you could just manage to hang on if one of your front tires blow while mowing at high speed!
I would not use water to clean the deck. You are just inviting rusty bearings.
Richard
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2025 JMR 40in Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A51039)
John Deere 946...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2006 International 9400i (A51039)
2006 International...
2008 FORD F-750(INOPERABLE) (A50854)
2008 FORD...
