x540 low power, smells of gas while running
   / x540 low power, smells of gas while running #11
You need to change the oil if one has been ran on only 1 cylinder for any amount of time.
It may check overfull of oil because gas is getting into the oil. Smell the oil...
   / x540 low power, smells of gas while running #12
Ehiz
I have International harvester 434 tractor gas model.
It smells like gas and low power when running. I can smell gas from the exhaust pipe.
can someone tell me what problem is?
I run it one time with the choke wide opened. When I saw it I quickly closed the choke an after that
I started having this short of power problems.
   / x540 low power, smells of gas while running #13
Probably post this in the International Harvester Forum, as you have your question in the John Deere Lawn and Garden Forum.
Try this one.
http://www.tractorbynet.com/forums/general-lawn-garden/
But maybe someone will still be able to help, but may be a stuck float in the carburetor getting too much gas into the intake. What is the engine make and size in the model 434?
2009 MACK CXU613 FLATTOP SLEEPER (A55745)
2009 MACK CXU613...
2008 CATERPILLAR 924G (A55745)
2008 CATERPILLAR...
16 T/A TRASH TRAILER (A55745)
16 T/A TRASH...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
