x500 or x534 your preferrence?
   / x500 or x534 your preferrence? #1
e01909
Nikiski, Alaska
dont
I'm looking at getting a jd tractor that can rototill / blow snow within the next two years. Is the cornering / steering that much of a difference between the x500 and the x534?
   / x500 or x534 your preferrence? #2
Welcome to TractorByNet!
We moved your thread to the John Deere Lawn & Garden forum. :)
   / x500 or x534 your preferrence? #3
I'm not sure about the steering difference but if you are considering a snow blower I would go with a model with hydraulic lift. I have the X530 and the hydraulic lift for the heavy blower is nice. I think I read that the X500 with the blower is fairly heavy on the mechanical foot lift. There is a spring assist that makes it a little easier but that is an option. Also I thought I read that you can't put chains on the 4 wheel steer model. Not sure about that. Maybe someone else can confirm.
   / x500 or x534 your preferrence? #4
Not totally sure but I would check the tiller compatability on the 534.
   / x500 or x534 your preferrence? #5
The turning radius of the X500 is 22", for the X534 it's 27".
   / x500 or x534 your preferrence? #6
Roger that! The hydraulic lift is a must.
   / x500 or x534 your preferrence? #7
You can put chains on a X534.
Do you expect any one to believe that statement?LOLOLOLOLOLOLO
   / x500 or x534 your preferrence? #9
OK, a X534 is 4 wheel steer, the X500 is not.
If the X500 turns shorter, why offer the X534?LOLOLO
Another "don't believe every thing you read on the internet"
   / x500 or x534 your preferrence? #10
According to the 2014 JD specifications on their website:
Uncut circle radius: X500 24", X534 13" (both with 54" deck)
Turning radius: X500 22", X534 27"
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
