X485 Transmission Oil Cooler Location?
   / X485 Transmission Oil Cooler Location? #1
italyguy01
Pa
X485
Is the Transmission oil cooler behind the radiator? Manual says to clean the transmission oil cooler fins, but doesn't specify location.
Thanks!
   / X485 Transmission Oil Cooler Location? #2
Thanks!
My 445's (which were the forefather of your machine) had theirs inside the radiator.
Maybe the manual meant to clean the rad fins to make sure of proper cooling of both the engine and trans. It wouldn't be the first mistake in a JD manual, believe me.
Looking at the parts break down on JD parts, it looks like you should be able to follow the two hydraulic lines from the trans up to the cooler.
Thank you!!
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
