X485 Transmission Oil Cooler Location?
   / X485 Transmission Oil Cooler Location? #1
italyguy01
Pa
X485
Is the Transmission oil cooler behind the radiator? Manual says to clean the transmission oil cooler fins, but doesn't specify location.
Thanks!
   / X485 Transmission Oil Cooler Location? #2
Thanks!
My 445's (which were the forefather of your machine) had theirs inside the radiator.
Maybe the manual meant to clean the rad fins to make sure of proper cooling of both the engine and trans. It wouldn't be the first mistake in a JD manual, believe me.
Looking at the parts break down on JD parts, it looks like you should be able to follow the two hydraulic lines from the trans up to the cooler.
Thank you!!
2018 DODGE RAM 1500 (A53843)
2018 DODGE RAM...
2- FREIGHTLINER BATTERY BOXES WITH BRACKETS (A53843)
2- FREIGHTLINER...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
Harrell 3605 (A50123)
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
