X485 Probem?
   / X485 Probem? #1
italyguy01
Pa
X485
Hello, I have an X485, only about 130 hours on it. I started it up the other day, and when I was raising/lowering the deck, it seemed a lot louder then normal. So I cycled it up and down several times, no difference.
I shut the tractor off, and I went to check the Hydro fluid, when I unscrewed the dipstick, there was a bit of pressure released when I opened it. Fluid level was fine, clean (I changed the fluid/filter not too long ago). So I screwed it back down and restarted tractor, all is ok now? Any ideas? What would cause the pressure? Something wrong?
Thanks in advance
2019 FREIGHTLINER CASCADIA DAY CAB (A54607)
2019 FREIGHTLINER...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2017 PETERBILT 579...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
