X485 Beeping / Hourglass flashing?
   / X485 Beeping / Hourglass flashing? #1
italyguy01
Pa
X485
Hi everyone, I have a John Deere X485 tractor. Love it. It now has 105 hours on it. Today when using the tractor, I noticed that the hour glass is flashing, and there is a beep every 4-5 seconds.
Is this normal, I don't remember every noticing the beeping before or the hour glass flashing.
Thank you!
Also, When I do perform service (Changing oil, fuel filter, etc), Do I have to reset service? How do you reset service timer/indicator?
It is not on yet, but just curious.
   / X485 Beeping / Hourglass flashing? #3
First of all welcome!!! I had a X495 and I think I remember there being something on resetting the Hour glass meter in the manual. Did you do a search on here. You might have to put in X465, x475, X485, or X495 as they all would be the same but not bring it up in a search.
Thank you. I couldn't find anything in the manual or on here, Unless I missed it?
   / X485 Beeping / Hourglass flashing? #5
Check on p 49 (if manual is the same as my X485).
In the index, under "Setting service indicator light", should be reference to where the button is located (remove leftside screen).
To reset, push yellow button in with key on. Hold until service indicator light blinks twice on the instrument panel.
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
66'' root grapple (A53421)
66'' root grapple...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
ELECTRIC GOLF CART (A53843)
ELECTRIC GOLF CART...
Ammco Brake Machine (A53424)
Ammco Brake...
