X320 ---> X380
/ X320 ---> X380 #1
millers1
Eastern - West Virginia
Deere 2210, X320
I'm thinking of replacing my X320 with a comparable X380. I do quite a bit of backing due to obstacles so I did the reverse safety (RIO) jumper as soon as I got the 320. My question is, is the X380 set up the same as far as the RIO bypass?
/ X320 ---> X380 #2
May not be exactly the same, so some 'search and destroy' or 'search and alter' may be in order. But likely you can figure it out.. I found it easiest to crawl under and look when the deck was removed.
/ X320 ---> X380 #3
What year is your 320? I don't think there is much difference with the 380 -- really the only major change is the new accel deep deck. Otherwise the specs are the same.
/ X320 ---> X380 #4
I removed the switch from its location and jumped the connector. This can be done on all machine with a reverse switch. All it detects is when you push the reverse pedal, trace the system, remove the switch, jump the terminal.
(INOP) KUBOTA M9000 TRACTOR (A62130)
(INOP) KUBOTA...
36" X 72" CONCESSION DOOR (A62131)
36" X 72"...
UNUSED RAYTREE RMBD50 - 50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
7102 (A61567)
7102 (A61567)
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
