X320 mower belt keeps breaking.
/ X320 mower belt keeps breaking.
Most of the times I have a belt break before it痴 time it was caused by a sloppy tensioner mount that痴 letting the pulley run at a misaligned angle. I also run after market belts. The 160 long belt on my Grasshopper cost about $50 but the shorter belts are less than $20. I paid $12 for the pump drive belt on my Grasshopper. The belts on my Dixie chopper were about $15. Are you letting the belt guards fill up with trash? That痴 another leading cause of bent failure IMO.
I have noticed some grass debris around the spindle with the plastic cover but nothing too large. I'll have another look at the idler wheel to make sure it's lined up. The end of the spring on the idler wheel arm wore a groove into the metal so I switched it to the hole on the top of the idler arm bracket. Same result, broken belt.
/ X320 mower belt keeps breaking. #22
Make a friend. Tell him all he has to do is pull a switch and hit the reverse pedal and he wouldn't go through that reengaging nonsense.
Or... show him how to stick on a jumper like I have on my X500 and become a GOD. :)
/ X320 mower belt keeps breaking. #23
I have the 48" deck on my X500 and have completely given up on those plastic spindle covers. I would blow them out with the leaf blower after every mow and they would still get packed full of debris. I've had them off now for 3 seasons and the spindle area stays clean as a whistle.
/ X320 mower belt keeps breaking. #24
The JD fan boys don't understand that green isn't perfect.
Nothing is perfect. A machine is a machine and green machines use the same cheap parts in certain areas as do other machines.
/ X320 mower belt keeps breaking. #25
Yep, a worn idler bracket can contribute to a belt breaking if it allows the belt to get pinched. Question is, has this done this since new and possibly was there also a bend from something before you had gotten the deck. A weird thing that happens on the vee idler is that the bearing comes loose in the bore allowing the pulley to wander on the bearing.
/ X320 mower belt keeps breaking. #26
that wouldn't cause a clean break, though, you'd see signs of extreme wear..
I have been breaking 1-2 belts a year since the 2nd year. It’s gotten worse this year (4). I replaced the idler wheel 3 years ago but I believe the rest of the bearings are original.
/ X320 mower belt keeps breaking. #28
For anyone following this thread: there's a known problem with the Edge 42" deck used on the X300 series. On the right hand ("passenger") side the height adjustment bolt is too close to the belt. On my mower, the belt actually touches the adjustment nut (when not running) if the mowing height is set to anything 3" or above. There's a service bulletin from years ago that instructs the service person to cut 1/2" off that bolt, which won't do any good on my machine. There's a YouTube video showing a fix that requires some complex welding. I have recently spoken to an attorney who intends to file a class action lawsuit against JD for what is obviously a design flaw that has cost owners thousands of dollars in replacement belts, but most of these mowers will be in the junkyard well before that can get past discovery.
/ X320 mower belt keeps breaking. #30
Please post that link, there's probably an easier/cheaper way to fix this, maybe adding an additional idler pulley to keep the belt away!..
/ X320 mower belt keeps breaking. #31
The forum won't let me post a link until I have three posts... You can search Youtube for "John Deere x300 mower belt breaking prematurely"
I found another way to fix it. May or may not work for you. First, make absolutely sure that the mower is leveled. This is important, because you're going to cut a chunk off the socket head screw (part M164280, shown as 26B on JD diagrams at XXXX://partscatalog.deere.com/jdrc/sidebyside/equipment/68603/referrer/navigation/pgId/2424937) --replace XXXX with the proper command.
That's the bolt that holds the mower up. Examine that bolt on the right hand side ("passenger" side) of the mower. You will likely find that the belt rubs against it and/or the nut that holds it in place. If so, you can cut the excess off. At the same time, make sure that the "lift link" (part M164279, shown as 27B on the previously referenced diagram) is placed so that the longer side faces up. (This will make sense when you disassemble the bracket.) With the longer part of the link facing up, it's actually possible to put the nut behind the bracket, which clears the belt. In order to tighten the nut, however, you have to prop up the right hand side of the mower deck to expose the nut. I did it with a piece of 2x4 on edge.
I am almost ready to get rid of this X320. I have been using the cheap belts for a year now and they last for about a half season before breaking. Last week I decided to try the OEM belts again, $92 and it lasted 5.4 hours before it snapped. Pulleys are tight, blades are spinning freely and I cut the bolts off that hang down. It must be something else. I have lost all faith in JohnDeere products.
/ X320 mower belt keeps breaking. #33
Pibster,
https://www.tractorbynet.com/forums/john-deere-lawn-garden/425157-link-belt-x300-mower-deck-3.html
See post #25
See this from RickB:
Re: link belt on x300 mower deck and pto clutch operation?
Small, because a properly engineered and assembled belt drive and conventional electric clutch coupled with a high quality (Kevlar) belt will give hundreds of hours of trouble free service.
Richard
/ X320 mower belt keeps breaking. #34
My LA145 PTO was always engaged at full speed, and I never had a belt break or squeal after hundreds of hours!!. I am 100% convinced that there is a design flaw in the X300 series that causes this problem. it seems JD was trying to put out a lawn tractor with seemingly impressive features, but then, trying to penny pinch on the quality..
/ X320 mower belt keeps breaking. #35
Some folks have a time with these belts breaking. I make sure they know about the MIR switch rather than cycling the deck switch constantly to back up. The new Accel deck doesn't seem to have this problem. The belt is thinner and 2 inches shorter. For only 79.99$ since I know ya priced....
/ X320 mower belt keeps breaking. #36
That doesn't make sense. Just to confirm, are you talking about the belt from the PTO clutch to the deck or the deck belt that runs the spindle pulleys?
The X300 and X500 share the same frame, lift mechanism and same 48-inch and 54-inch mower decks. So if there was a design issue the X500 models would be having the same problem. I'm currently at 325 hrs on my X500 and both the primary and secondary deck belts still look perfect.
/ X320 mower belt keeps breaking. #37
My X300 only has one belt that routes around the PTO and the spindle pulleys. My Crapsman has the same set-up but can be engaged at full throttle with no slapping or bogging. Only thing I can figure is the routing or tension of the idler spring.
/ X320 mower belt keeps breaking. #38
mine only uses 1 belt to run the spindle pulleys. the other belt is for the wheel drive, so I only have 2 belts!..
Tri Axle Rolloff Truck (A64194)
Tri Axle Rolloff...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
John Deere 230 Disc Harrow (A66285)
John Deere 230...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
