x300 will not move or PTO will not engage
   / x300 will not move or PTO will not engage #1
otto5005
Woodbridge, VA
JD / x300
HELP! Just got hit with massive snow here and can't get x300 to move to push snow. Engine cranks and starts right up. Pushing the forward or reverse pedal does not give an movement. Also, pulling up on PTO does not engage mower. Main drive belt seems loose. Is there anyway to adjust tension? Or it would it be another problem. Many thanks for help.
   / x300 will not move or PTO will not engage #2
Are you in neutral?
Sent from my iPad using TractorByNet
No, I have the pin in the back pushed in, so I wish it were that. The pedals feel a little soft for some reason.
   / x300 will not move or PTO will not engage #4
I know this is old but any chance you figured it out? I’m having the exact same problem. Definitely not in neutral.
   / x300 will not move or PTO will not engage #5
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
