x 304 aws question
   / x 304 aws question #1
Lone Oak Landscaping
Orange county N.Y.
NewHolland TC40DA
Bought a mulch kit for the deck from John deere,came with a mulch plug and two blades that bolth say RIGHT on each blade.
The owners manual says to make sure you put the mulch blades on LEFT and RIGHT sides correctly .
The instructions on the kit say nothing about LEFT or RIGHT hand blades.
Any one know if there should be two different blades ?
Thanks for any help.
   / x 304 aws question #3
Both blades turn in same direction I believe to help push grass out the chute.
   / x 304 aws question #4
no such thing as a left and right blade unless you're cutting hay. just make sure you put them on with the correct side facing up/down. happy mulching.
   / x 304 aws question #5
Actually, there are some two-blade decks that use different size blades. I remember Simplicity makes one, maybe for the Regent. Seems to me that Deere has (or had) a deck model that used two different size blades as well.
   / x 304 aws question #7
I would let my finger do the walking. Right to my local Deere dealer for a conclusive answer.
   / x 304 aws question #8
Had the blades off mine 2 weeks ago to sharpen them. They are both identical. Make sure they're right-side-up & you're good to go.
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
CABINET (A53843)
CABINET (A53843)
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
2014 Rockwood Premier 2317G 23FT S/A Pop Up Camper (A51694)
2014 Rockwood...
